After uploading new files to player, it froze, but I thought nothing of it. All file's were succesfully done.
I just tried to open Jemplode, and it got, up-to filling all the "rogress bars", and does nothing...
I found stated error's, except dont know what they meen:
empeg-car bootstrap v1.02 20001106 (
[email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg51 (mac@aphex) (gcc version 2.95.3 20010315
(release)) #16 Wed Jul 24 18:19:54 BST 2002
empeg-car player (hardware revision 9, serial number 40104276)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 00002440 '@$'
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005000).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHM2100AT, ATA DISK drive
hda: FUJITSU MHM2100AT, 9590MB w/2048kB Cache, CHS=19485/16/63
smc chip id/revision 0x3349
smc9194.c:v0.12 03/06/96 by Erik Stahlman (
[email protected])
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:10:b
4
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComðStarting
player
Vcb: 0x4086d000
????THANK'S????
